design of temperature regulator
assuc
Joined Mar 23, 2012
77
Greetings,
Could anyone help me explaining the following circuit
Actually i have been assigned to build a circuit with pi controller to maintain the temperature set point of 40C of an incubator. the above is proposed to be used as the first stage before pi controller.
Explanation with mathematical relations would do great.
assuc
Joined Mar 23, 2012
77
I have made the following pi controller design but in this the relay does not switches when temp goes above 40
What could be the problem?? Please figure it out asap.
REFERENCEhttp://www.ecircuitcenter.com/Circui...pid/op_pid.htm
bertus
Joined Apr 5, 2008
23,026
How are the opamps powered?
It can NOT be a single supply, as some of the inputs of the opamps are grounded.
Brownout
Joined Jan 10, 2012
2,390
You don't need all those amplification stages. And what is the purpose of the U2 stage? You need one stage configured as a wheatstone bridge ( as the first stage in your textbook is configured ) and a transistor switch. Maybe one stage of amplification on the front end, but probably not.
assuc
Joined Mar 23, 2012
77
All opamps are poered via a single 12volt variable power supply and all the grounds of opamps are common
assuc
Joined Mar 23, 2012
77
Basically its a PI controller to control the temperature(as in this case 40 C) of the incubator box. U2 is the integrator whose output is summed up with the proportional controller output
Brownout
Joined Jan 10, 2012
2,390
I answered that in post #7.
There are many schematics that implement this simple control method. Quickly searching "opamp wheatstone bridge" and "temperature controller" should produce a torrent of information.
bertus
Joined Apr 5, 2008
23,026
As I told you before: the inputs of the opamps can NOT be put to ground on a single supply.
The opamps can NOT have any input voltages below the ground value.
You will need to compare the output of the LM35 with a reference voltage.
At 40 °C the output voltage of the LM35 will be 0.4 Volts.
Adding a hysteresis will prevent the relays from scattering.
On this page of the eBook you will find some info on this:
http://www.allaboutcircuits.com/vol_3/chpt_8/12.html
assuc
Joined Mar 23, 2012
77
if that was the only case i wouldn't have posted here, its difficult for me to choose out of tons of schematics so this was the only source to seek infromation!
