Dehumidifier repair - SMPS question
tjfs
Joined Dec 4, 2020
5
I am repairing a dehumidifier which won't power on, and I've isolated the problem to missing 5v to the CPU. I found the diode which rectifies the 5v rail before the 7805 rectifier was short. Surprisingly, when I remove the bad diode and power up, I have 7.5Vac at the transformer output, so it would seem the shorted diode didn't damage anything else. With no power supplied to the unit and a 9v battery connected to the input of the 7805 via a 48 ohm series resistor the CPU powers up and displays information on the LCD, so that seems to prove the circuitry downstream.
The SMPS is a simple design with a LNK625 driving a small E16 transfomer with a feedback winding and two secondaries. Both secondaries produce 7.5Vac. One output is rectified, smoothed and feeds the 7805, the other output is rectifed, smoothed and goes .. nowhere. I'm tempted to steal the diode from this output as it appears the same type. Probably best not to just bridge the output across as the second output winding might be lower current. The transformer is marked HS20411/E16 CQC however I can't find any information about it.
The dehumidifier is Chinese manufactured and was sold in the UK by B&Q as WDH-930DAH. The power board is labelled D2514-790.
Any thoughts appreciated.
Dodgydave
Joined Jun 22, 2012
11,395
Post pictures of the PCB , if you want to swap diodes go ahead, but your meter won't read the AC voltage correctly as it's in the kHz region .
Dodgydave
Joined Jun 22, 2012
11,395
Looks like a UF4007 type.. this is the circuit diagram from the datasheet..LNK625pg
Yours looks like it has a diode from the middle winding to ground in front of the Transformer, ??
tjfs
Joined Dec 4, 2020
5
There are two secondaries, no centre tap. The PCB layout is strange!
I have the dehumidifier working for now with a 9v battery providing power on the input side of the 7805 and the mains powering all the usual components. Replacement Schottky diodes are in the post, should arrive next week.
I calculate one 9v alkaline battery will power the unit for about a day of continuous operation, which is reasonable.
Tim
tjfs
Joined Dec 4, 2020
5
The problem with that is the design uses the voltage at the input of the 7805 to power the relays.
I could certainly use a 9v mains supply instead of the battery, but I'm hoping the diode will fix it.
tjfs
Joined Dec 4, 2020
5
New SR2100 diode arrived today, unit is working again. Thank goodness the SMPS control IC saved other parts from failing.
Thanks for your post. It pointed me to right direction. I also used you trick with 9V to 7805. My Fral DryDigit 20 LCD dehumidifier also stopped working. It was the same problem with SR2100 Szottky diode after transformer. Everything else survived. I will Post some photos for posterity. 2D11312F-B837-4A9C-81AE-5E9CB62476DE.jpeg0B66F7FB-3BC2-4803-BC55-CB27979C8487.jpegE69151E2-BA7E-4741-B90F-CEF9FF1274AA.jpeg6FEDFE77-CEB2-4BA6-A283-1BC991ACD1C9.jpeg
HAL2100
Joined Dec 1, 2023
15
This was very helpful. Thank you.
I had exactly the same problem.
I didn't have a 2A diode, so used a 3A diode.
The dehumidifier is now back up and working.
They don't make things like they used to! This one died after 11 years of hot wet summer use. Thank God for the internet!
dacoo
Joined Nov 12, 2019
Thanks so so much, saved me hours of time reverse engineering the schematic and fault finding this.
I have a WDH-210DB-16R
I have a WDH-210DB-16R that suddenly died, no power to the control panel at all, no lights or buzzer. Buzzing out the power board with a DMM, the LM7805 5V regulator was not getting any voltage, yet 230V was at the fuse on the board.
Luckily I stumbled across this thread and my board had indeed failed with the SR2100 diode becoming Short Circuit.
Removed and replaced with another larger 3A diode (SB340) I salvaged from an old Computer PSU, hoping it will last a bit longer than the original given it is a higher current rating.
Pictures attached showing old failed Diode, new Diode, PCB holes drilled slightly larger to accommodate the new larger SB340, and pads made larger for reliability, last images show the 5V rail sitting at 4.95V again as it should and the new diode only at 23C under load.
Very happy to have the dehumidifier back up and running, and properly grateful to this forum and you all for your posts.
Dan
