Defining the term: "Amplifier Stage"
Dynaman
Joined Jan 17, 2008
94
Greetings fellow AAC'ers
How do folks define a "stage"? Separate amplifying elements? or a group of amplifying elements serving a specific purpose?
38,412
Generally an amplifier stage is the components in an amplifier that have an internal input and output with gain in between.
There can be one or more stages in the complete amplifier to get the desired overall gain and frequency response.
BR-549
Joined Sep 22, 2013
4,928
I can not find a formal definition. I would say a stage.....is just the area of circuitry under discussion, analysis or design.
Dynaman
Joined Jan 17, 2008
94
Okay, so we are agreeing with separate amplifying elements... I agree; however when there is parallel staged circuitry involved, it becomes difficult to serially designate each stage name when the signal path splits off in several directions. Sorry for being vague.
AnalogKid
Joined Aug 1, 2013
12,088
Sounds like you are describing a specific piece or class of equipment. Are you?
Also, is it important to "serially designate each stage"? If so, why is it a problem if the stages are physically or electrically non-serial? Note that resistors are capacitors are serially designated even though they can splattered be all over the place.
ak
Dynaman
Joined Jan 17, 2008
94
Hmmm... Well it sort of is when you are trying to find ground loops. It becomes a bit cumbersome when you are trying to follow a signal, and then it splits off into feed back somewhere else into other stages at the same time. Then I try to figure out which stage takes priority in order to keep ground points in order so as not to loop anything. I guess I need to think this through a bit more.
JMW
Joined Nov 21, 2011
138
https://www.wikihow.com/Read-Schematics
Try this. It has been awhile since I taught this. After several decades it is 3rd nature. I feel for you. I remember struggling through military manuals as a boot ET. They developed a flow chart type, can't remember the name. It was a great help. The only problem was that it took 10 or 15 square feet to use. Impossible on the bridge of a boat. Got out of the military and struggled through RCA, GE, Motorola and host of others. I consider a "stage" to consist of a single active unit and the associated passive components. In a parallel circuit, such as a push-pull, I consider also a single stage. Where a signal branches to provide feedback or source another function, I consider those separate stages or possibly even separate circuits.
I would help if you could post the schematic and highlight areas of confusion
27,316
Sometimes it is a bit challenging to accurately define a "stage", but mostly, in analog circuits, a stage is indeed the components associated with an active device, usually a transistor at present. A stage can also be defined as a segment of a circuit with a single function, which is good most of the time.
