I have 2x 40AH batteries in my gopher. Std is 34AH wet cell. I discharge them at abt the 3hr -3.5hr rate for up to 2.5hrs. The batts are 4mths old, and I'm noticing acute random speed variations with no change in Vcc after abt 30min running as of last 2 weeks. Batts test ok, and motor has new brushes. I can't verify connections as I can't bend/kneel down to it. Weather is warmer now. What difference will it make if I interrupt discharge for 5 min every 15min? How much power is being taken from the batteries at present rate and ditto if the rested rate? What lifespan can I reasonably expect if used at least 3x/wk? I use a 10A 4 stage intelligent charger, and usually float the batteries unless using them. Temp is abt 30degC atm, and on its way to 40+ in shade. NB a Daning bicycle computer appears to have fried in direct sunlight--recommend me something better. I need the long range to get anything done, shops etc are just too far [~1hr] for anything less, tho' I could reduce speed..... Avg. motor current varies from abt 6A to 30A load dependent. most local hills are modest and short, taking only 1 or 2km/h off the pace, but sufficient to increase Avg current to 30A for 1~2min at full speed.
