12.3 volts on a battery indicates it needs to be charged.
IMMEDIATELY after charging a good battery will show a voltage above 13 volts and it will stay there for many many minutes even hours.
If a battery has a shorted cell and is placed on a long charge ending at 2.5 volts per cell.
It WILL show 12.2 to 12.6 volts IMMEDIATELY after charging.
So a battery that is just a little run down and battery with a shorted cell CAN read the same depending on when and how the batteries are checked.
Quoting me and just saying I'm wrong is not helping.
Investigate the term "excess surface charge" as it is used in discussions of lead acid battery charging behaviors.
