dc voltage generation
falade47
Joined Jan 24, 2017
178
How are dc generators able to generate constant dc voltage if the coil with constant velocity rotates in a uniform magnetic field
shortbus
Joined Sep 30, 2009
10,049
If you are talking a generator and not an alternator, the field is not a "uniform magnetic field". It is a variable magnetic field, controlled by the voltage regulator. This is also true for an alternator, except that an alternator puts out AC that is then rectified into DC.
falade47
Joined Jan 24, 2017
178
So are u saying a dc generator actually produces ac then a rectifier comes up..?..yeah I think I kinda experienced that from my gasoline generator *key series..i put my hand on the terminal of the batteries after putting the generator on..to my suprise I received a shock which was definitely from the alternator charging the battery..#please Is there a rectifier in conjunction with the alternator charging the lead acid battery or it uses ac to charge which I dont think is possible
