DC Uninterruptible Power Supply
james211
Joined May 29, 2012
291
I'm curious if anyone can help me track down some parts or give me some advice. I have a Pepwave MaxTransit Duo cellular router that I use for work. Often times I have to run it off of batteries because I need to be completely mobile. When the batteries die, the unit takes about 10-15mins to reboot so I'd like to get some sort of mini DC UPS to use that will allow it to stay powered while I swap the battery. I found THIS UNIT on mini-box.com which I think could work, but it also seems a bit overkill (correct me if I'm wrong). The router works between 12-48v with a max power consumption of 18w(9.2nominal).
This is also an interesting find, anyone ever used a SuperCap based UPS?
LowQCab
Joined Nov 6, 2012
5,102
Do you have 2 Power-Input Connectors with "ORing" capability on your device ?
If you do, and you have 2 Batteries, plus an AC-Powered-Supply,
why do you need anything else ?
~15-Minutes to reboot ?!?!?! , I'd send it back.
bertus
Joined Apr 5, 2008
23,041
Did you see the backup time for the mentioned board?
With 18 watts at 12 volts, the current will be about 1.5 Amp, giving a backup time of 30 seconds.
Bertus
Ya’akov
Joined Jan 27, 2019
10,370
Looking at the device I don't understand why you have to "swap" batteries. Since you can't charge the batteries anyway, why not just wire them in parallel to the device and increase the overall capacity?
james211
Joined May 29, 2012
291
I work in film production, and I use industry standard Anton Bauer batteries to power the router. I basically want to eliminate any downtime for the client so having the ability to swap out the battery without losing connectivity, while at the same time keeping the overall size minimized.
Ya’akov
Joined Jan 27, 2019
10,370
Are you using V mount? You can get a dual plate and adapt that so you can swap batteries one at a time, or you can get something like this: https://www.bhphotovideo.com/c/prod...gineering_ml_120v_v_hot_swap_adapter_for.html
If you are using gold mount, you can adapt a camera plate that has hot swap.
