DC supply for AC circuit?
John Douglas
Joined Aug 7, 2016
8
I have a power supply board that supplies 24-0-24VDC to two 20W power amps, this PSU also has a 15-0-15VDC output. I am now installing a pre-amp that requires 12-0-12VAC supply. Would it be ok to use the 15-0-15VDC to power the pre-amp? The pre-amp was a kitset that I assembled myself, would it be better is I bypassed the rectification part of the circuit?
ericgibbs
Joined Jan 29, 2010
21,552
hi John,
Some units are wired the same way as you describe and will accept DC or AC inputs.
I would bypass the rectifiers, ensure that you have the correct polarity and use a non reversible DC input connector.
E
