dc power jack female plug connector
AlbertHall
Joined Jun 4, 2014
12,653
What I do is to put the 40 pin IC in the schematic. Then, when the board is made, fit the socket in the holes made for the IC.
If you had a separate part for the socket then the schenatic would just show a box with numbered pins. The method above means that the schematic will show the actual IC connections and make it much clearer what is going on.
