Hello !
i want to measure voltage and current about a DC - overheadline in two different substations. The DC voltage is about 700V and the current about 1000A.
My idea is to measure the current above a shunt resistance. The shunt resistance has a Current /Volt ratio of 1000 A = 40 mV.
I have to record this data and sync it.
So my question is if you hade some ideas which device i can use. It should have the property to DataLog (round about 18 000 logs). Maybe its possible for measure with two channels. (both DC V!)
And i have no clue how to sync this logs except later manuel at the PC.
greetings
greetings
