Dc fan question
mansoor001
Joined Apr 23, 2019
7
Hello Friends/Users
I have 4 amp dc fan can i run this fan through 3.5 amp charger or 3 amp charger
I will be thankful to you
Regards
shteii01
Joined Feb 19, 2010
4,644
so clamp meter will tell how watts a dc fan is taking
The clamps that I have measure current.
Once you set the fan speed, you measure the current using current clamp, then multiply current by the dc voltage, that will give you the watts at the instant when you measured the current.
Sensacell
Joined Jun 19, 2012
3,787
Most "Clamp" meters measure AC current only, the DC versions are very expensive, specialized gear.
What are you measuring exactly?
