DC 9V Power Supply Chip Question
dl324
Joined Mar 30, 2015
18,329
A part number for the supply would be helpful. It would also be helpful if you traced the board and made a schematic showing the connections to the damaged part.
SamR
Joined Mar 19, 2019
5,491
Possibly a ICL7660S Voltage regulator (or similar) as from what little I can see of the board I can't tell if there is a TO-220 regulator on there.
Marley
Joined Apr 4, 2016
519
Looks like it is the switching control circuit as it is on the HV side of the supply.
It may have a high-voltage MOSFET inside, or this may be separate under the PCB.
Hate to say this, but it's not worth repairing!
dendad
Joined Feb 20, 2016
4,637
Just from the look of it, I think the bin is the best place for this supply. The power supply does not appear to be designed with good safety in mind. Is there any isolation slots between the primary and secondary sides for instance?
These sort off supplies are very easy to get so I think a replacement is a good idea.
And cheaper than parts to fix the old one.
ci139
Joined Jul 11, 2016
1,989
there is a coil wire coating isolation weakening mechanism described in an article - where they show how the channels develop inside the laqcuer over time leading to isolation failure - it might be the primary cause here -- the "short" (over sparking) turns in primary cause core saturation - cause the current peaking (without risen voltage at secondary - so it won't get limited by any means) leading to excessive currents on mosfet - leading to overheating and failure . . .
or
the filter cap next to controller was degrading and caused the chip to fail
... it is unlikely a simple repair
electhobby
Joined Feb 12, 2020
6
Update: I replaced a bad capacitor (Circled in picture) 470uf/25v. When I removed it and tested it, it only had 1.5uf.
Still trying to figure out what chip that is squared below. Thank you.
