DART Project Set To Launch This Month
MrAl
Joined Jun 17, 2014
13,812
Well they finally got around to doing the impact mitigation project and it looks good.
The idea is to test on an asteroid that is out in space already just to see if it works right.
I think i would want to have at least three of these crafts in space just in case the first two dont work or are not enough, after all they will be depending on models to do the calculations.
A little worry is that during the test they disturb the local object field and send some hurdling toward earth. Hopefully there is little chance of that happening.
MrAl
Joined Jun 17, 2014
13,812
Not if was going to fly by at a distance of 1.2 MegaMiles. Whachoo smokin' Willis?
Maybe he is smokin the infinite time syndrome, where if it goes around enough it will eventually reach a flight path that intercepts Earth. If it takes too long though Earth might not be here anymore anyway.
