CY8C20110-SX2I Not Responding via I2C with ESP32 – No Touch Data or Output
nirajbabuaan
Joined Jun 11, 2025
Hi all,
We’re working on a custom PCB under our startup “Slogfy” where we’ve integrated the CY8C20110-SX2I capacitive touch IC with an ESP32 microcontroller. However, we’re not able to receive any data or touch status over I2C.
IC: CY8C20110-SX2I
Microcontroller: ESP32 (using Arduino IDE)
I2C Pins: SDA = GPIO21, SCL = GPIO22
Pull-ups: 4.7kΩ on SDA and SCL
I2C Address: 0x00 (or configured value)
Status: ESP32 detects device on I2C bus with scanner, but data read always returns 0 or fails.
We’ve attached:
Our Schematic (PDF/image)
PCB layout (image)
Screenshot of serial output and code snippet
Things we've tried:
  • Confirmed 3.3V and GND supply is OK
  • Confirmed I2C lines with logic analyzer
  • Tried different delays and requestFrom() patterns
  • Used both Wire.h and other I2C libraries
Please help us identify what might be wrong—whether in hardware, address configuration, reset handling, or timing.
Thanks in advance
– Team Slogfy
nirajbabuaan
Joined Jun 11, 2025
hi niraj,
Welcome to AAC.
I do not see the ' Screenshot of serial output and code snippet '?
E
C-like:
#include <Wire.h>
#define SDA_PIN 21  // Use GPIO21 for SDA
#define SCL_PIN 22  // Use GPIO22 for SCL
void setup() {
  // Initialize serial communication
  Serial.begin(115200);
  delay(1000); // Give time for serial monitor to connect
  // Initialize I2C with specified SDA and SCL pins
  Wire.begin(SDA_PIN, SCL_PIN);
  Serial.println(" I2C Scanner Starting...");
  Serial.print("Using SDA: GPIO");
  Serial.print(SDA_PIN);
  Serial.print(" | SCL: GPIO");
  Serial.println(SCL_PIN);
void loop() {
  byte error, address;
  int count = 0;
  Serial.println("Scanning for I2C devices...");
  for (address = 1; address < 127; address++) {
    Wire.beginTransmission(address);
    error = Wire.endTransmission();
    if (error == 0) {
      Serial.print("✅ I2C device found at address 0x");
      if (address < 16)
        Serial.print("0");
      Serial.println(address, HEX);
      count++;
  if (count == 0)
    Serial.println("❌ No I2C devices found.");
  else
    Serial.println("✅ I2C Scan Complete.\n");
  delay(3000); // Scan every 3 seconds
"serial print is- ❌ No I2C devices found."
