Current Rating of low voltage transformer in Automatic stabilizer
rahulb
Joined Jun 5, 2019
44
Hi Everyone,
What should be the current rating of low voltage transformer used for buck and boost operation in an automatic stabilizer?
Is current rating of the transformer relevant for the operation?
thanks
rahulb
Joined Jun 5, 2019
44
If we knew what an "automatic stabilizer" was we might have a clue about the answer to you question.
hi,
I am talking about automatic voltage stabilizer which uses buck and boost to stabilize voltage in a certain range.
sorry, for the confusion.
thanks
Papabravo
Joined Feb 24, 2006
22,111
hi,
thanks
So you start with the AC mains and you want an AC output or a DC output. I ask because "buck" and "boost", are in my experience, used in DC-DC converters. So what are you actually trying to do? Where does the power factor correction come in.?
You have automatic tap changers and you can have motorized Variacs do the work too. You just don't want to switch the taps frequently.
I think the idea is to put a multiple-tapped transformer in series with the mains, so you can add or subtract from the line voltage.
Ramussons
Joined May 3, 2013
1,572
Hi Everyone,
thanks
Is the transformer being referred to the one for the Control Circuitry or for the Load?
If it's for the load, then the "low" voltage winding will need to handle the Load Current.
rahulb
Joined Jun 5, 2019
44
I got one pic of 140-280v transformer winding data, current rating 0.25 KVA
output is 220 v with variation of 9%. It is an auto transformer But I am not sure how it will work. If anyone knows, please tell me.transformer.jpg
Alec_t
Joined Sep 17, 2013
15,156
It will 'work' much the same as any other transformer, except that the windings are all in series so aren't isolated from each other. There is a consequent risk of electric shock!!
In itself it doesn't provide any stabilisation.
