cubes in a 4-d hypercube
LDC3
Joined Apr 27, 2013
924
Since the 4th dimension is beyond anyone's experience, all we can do is look at 3D shadows of 4D objects. The tesseract is the simplest object to view.
To find out how many cubes are in a tesseract, go to the table in the middle of the web page. On the row that says 4-cube, look for the column that says cells. That is the number of cubes in a tesseract.
djsfantasi
Joined Apr 11, 2010
9,237
Or draw the 3D projection of a tesseract and count the cubes directly. There is the inner cube, the outer cube (2 cubes) plus the projection between each of the 6 faces of these cubes (6 more cubes) giving 6+2=8.
33,325
The 3-D projection of a 4-D object is a 3-D object. Think of it like a "shadow". You are a 3-D object but your shadow is a 2'-D object. The shadow of an n-D object is an object in (n-1) dimensions.
