i use of 555 for convert voltage to frequancyyyyWhat crystal?
Why do you want to add a crystal?
Increase 555 to what speed?
From what to what? Schematic?i want increase speed ...
thanks.but lm2917 convert frequency to voltage not voltage to frequencyUse an Lm2917 chip. chip
voltage to frequencyFrom what to what? Schematic?
This schematic produces an output train of pulses at the same frequency, the only thing changing is the width of the pulses. The input on pin 2 (I assume this is where you want your crystal) retriggers the 555 at a set frequency. The RC network on pins 6 & 7, along with the voltage on pin 5, determine the duty cycle of the output on pin 3. I'm not sure what tw refers to, but I am guessing that it is the time the signal is high.voltage to frequency
with 555
Schematic:
this is work
but i think frequency output have delay
and if possible i want increase speed for convert
Any delay is so small that most folks don't worry about it. Changing the control voltage will change the output of the 555 within one clock cycle....but i think frequency output have delay
your means is:Any delay is so small that most folks don't worry about it. Changing the control voltage will change the output of the 555 within one clock cycle.
Define your needs. Perhaps you need a PLL.
that was going to b my suggestion.Any delay is so small that most folks don't worry about it. Changing the control voltage will change the output of the 555 within one clock cycle.
Crystal oscillator on Falstad Simulator. | PCB Layout , EDA & Simulations | 1 |
| Similar threads |
