creating a battery pack 12v
pollardive
Joined Dec 3, 2016
Hi all, new to this forum and looking a wee bit of advice please.looking to create a power pack from 18650 3.7v batterys to run a 12v heated vest. When fully charged Im getting 4.2v per battery so 3 in series is giving me 12.6v, that much is fine. When I connect heated vest, current drops voltage to 10v, which is not enough to power vest. OK, if i connect a 4th battery in series, giving 16v, connect vest and current drops to 13.8v which is great for running the heated vest. Is this good practice or should I add more batteries in parallel to provide a lower voltage?
Thanks in advance.
Kevin
Kermit2
Joined Feb 5, 2010
4,159
We need to know the specifications of the heated vest in order to give a factual answer. Otherwise we can only guess what will work
35,299
You need to match the load to the battery and vice versa.
Firstly, determine the current requirement of the vest.
Determine how long you need the vest to be constantly heated.
Multiply the current consumption with the number of hours of operation.
For example, if the vest takes 1A and you need to heat the vest for 1 hour, the current-time calculation is 1Ah or 1000mAh.
A 2000mAh @ 12V battery would be suitable in this case.
Kermit2
Joined Feb 5, 2010
4,159
With those figures the battery can maintain the vest for about 40 minutes before it is dangerously over discharged.
pollardive
Joined Dec 3, 2016
With those figures the battery can maintain the vest for about 40 minutes before it is with the dangerously over discharged.
thanks, but should i run with the 4 18650 in series with 16v to start or have 6 18650 ,3 series with 2 parallel with 12.8v to start with?
