I'm using a DC-DC (boost) converter to bump 12V up to 24V (approx.85W) - it's well within it's operating spec (max. 150W) and I've just noticed after about two 8 hour sessions of continuous use that the plastic skin on one of the large capacitors has split.
The X at the top of the cap shows no sign of bulge.
Is a split plastic skin nothing to be concerned about and part of the everyday behaviour of any cap that sees temp fluctuations?
It's fairly critical that this unit performs reliably over at least 7yrs and so if expansion of the cap suggests that there has been damage, however minor, then obviously this module is not for me! Perhaps even, the heat has caused the plastic skin to shrink and I need not worry about it at all!? Any thoughts would be hugely appreciated.
The module sits at about 50 degrees C (measurement taken from the heat sinks). It's max temp rise is 45 degrees C and it's start temp is approx 22 degrees C.
Thanks,
Fred
Thanks,
Fred
