counting from 10 to 0 decimal
le011
Joined Dec 28, 2018
17
hello all
i need to build a counter that counts fro 10 to 0 in decimal. i need to use 4029 counter , and use of 7 segment to show the counting.after reaching to 0 the count should stop.
ty for your help
38,926
So you need to use that counter with a binary to 7-segment decoder.
You need to add a circuit to detect the zero count and then inhibit the clock to the counter.
Also need a way to set the counter to binary ten (1010) before the count is started.
dl324
Joined Mar 30, 2015
18,491
Welcome to AAC!
9-0 or 10-0? It makes a difference.
Something seems to have been lost in translation because CD4029 can't drive a 7 segment display directly. Post the full text of the problem.
le011
Joined Dec 28, 2018
17
https://drive.google.com/open?id=1dZFOBPJrAhYVjGlxqordxnMAP1pR4O4thi all
ty for your quןck responseץ
well i tride to conect to 4029 in proteus to bcd 7 segments one digit , set the counter to count in decimal mod and counting down .but it count from 9 to 0.
i know i have to use 2 digit 7 segments and a driver betwen the 4029 and the 7 sigmets.
what i need i circuit that counting from 10 to 0 and displays it in decimal .
dl324
Joined Mar 30, 2015
18,491
In decimal mode, those are the only valid counts.
Please post the entire text of the problem.
CD4029 is a binary or BCD counter. How many counters are you supposed to use?
le011
Joined Dec 28, 2018
17
i dont have limitation about the number of 4029 to use. only limitation is to use 4029 for counting.
and make it as simple as posibel.
ty..
le011
Joined Dec 28, 2018
17
How many counters are you going to use? What is your definition of simple?
well for the start i used one and i saw its not good ressolt. so if ineded one more i will use it,
simple is the minimum parts using to do and show the counting
dl324
Joined Mar 30, 2015
18,491
Can't read labels. It appears that you're posting the circuit that didn't work. Post your idea for one that counts down from 10.
le011
Joined Dec 28, 2018
17
WELL, I CANT FIGURE ONE .YES THIS ONE NOT WORKING -ONLY COUNT FROM 9 TO 0 IN DECIMAL.
WHAT I NEED IS ACTUALY SEE IN THE SIGMENTS THE COUNT FROM 10 TO 0 LIKE IN HAPPY NEW YEAR COUNTING....
LOST HEARE...
TY
djsfantasi
Joined Apr 11, 2010
9,237
I don’t understand your issue. You need a second digit. So add it. You need to count down from this digit. So add something to do so. You need to connect the two digits so they count down together. Read the data sheet to learn how.
