Correct wiring for reverse polarity LED indicator?
Nikhil Chauhan 1
Joined Nov 6, 2017
Hello
I'm pretty new to electronics, I am currently designing a fuzz guitar pedal. I plan to use a 2.1 DC jack and a battery snap for PP3 9v battery.
I am concerned about reverse polarity frying my circuit and I have thought of a way to make an LED indicator to warn against reverse polarity. IMG_0724.PNG
EDIT to the picture: the diode should go after the LEDs to allow them to light before being redirected.
I have no idea if this will work and would like some feedback please.
MaxHeadRoom
Joined Jul 18, 2013
30,885
If you need an indicator, place a LED after the diode, if no light, then the polarity is wrong.
If concerned about the diode, place a decoupling cap after it.
Use a Schottky for low Fv.
Max.
MaxHeadRoom
Joined Jul 18, 2013
30,885
Not sure what you mean by CLR, the LED would be on all the time unless you come up with a way to clear it, you could always make it high impedance with a high value resistor.
Max.
dl324
Joined Mar 30, 2015
18,522
The circuit you posted won't work. The 1N4001 would prevent the red LED from turning on and would essentially short the battery when reverse connected. You only need one current limiting resistor, assuming the potentially different brightness of the different color LEDs wouldn't be unacceptable.
The suggestion of using a diode in series with the battery connection is the simplest solution; aside from using a battery connection that doesn't allow reverse polarity.
38,946
To avoid the forward voltage drop of a standard diode, you can use a single P-MOSFET to act as a (near) ideal diode and prevent damage from a reverse 9V battery connection (below).
Its forward drop is just the MOSFET ON resistance times the circuit current.
You might notice that the forward current is a reverse flow through the P-MOSFET, but that's okay, since FETs conduct equally well in either direction when ON.
If the battery input is reverse biased, the P-MOSFET is biased off and does not conduct, blocking any reverse current.
The P-MOSFET can be just about any device with a low enough Rdson to keep the forward voltage drop <100mV (or however low a drop you want).
Nikhil Chauhan 1
Joined Nov 6, 2017
Thanks for your responses guys. Much appreciated.
I think I'll look into the P-MOSFET solution or just do some experimenting (surely no massive harm can be done?).
