Conversion Process from mv to lbs
satti15790
Joined Jul 17, 2017
17
Can you please help me in conversion formulas
Is there any direct formula to
Convert millivolts to lbs?
Convert Hz to rpm?
Convert millivolts to °C?
if not, these are my requirements
Input:0-1880mv±5mv
Output:0-1540lbs ±10lbs
One more,
Input:0mv-29.3mv±75µv
Output:0-700°C ±4°C
if Possible can you provide explanation?
Thanks in advance
Satish
ericgibbs
Joined Jan 29, 2010
21,552
hi,
To get a Scaling Factor, divide 1540lbs/1880mV = 0.819lbs/mV
700C/29.3mV = 23.89C/mV
Is this what you are asking, what is the application.?
Normally you would configure an amplifier to do the scaling,
E
WBahn
Joined Mar 31, 2012
33,111
Where are these needs coming from?
It's like asking if there is a direct conversion from liters to kilometer/hour.
Exactly what is it that your inputs and outputs represent?
Based on what little you've given, here are your "formulas":
mv to lbs: 819 lb/V
mV to °C: 23.9 °C/mV
You haven't aid what your input/output spec is for the Hz to rpm, so that's up in the air.
satti15790
Joined Jul 17, 2017
17
Yes is there any direct conversion?
Those inputs are coming from sensors...
so if i read 1880mv as input i should convert that value to lbs i.e 1540lbs
satti15790
Joined Jul 17, 2017
17
hi,
E
0.819lbs/mv is it equal to 0.819lbs?
23.89C/mV equals to 23.89C?
WBahn
Joined Mar 31, 2012
33,111
That's not a direct conversion. It's a scaling process. You millivolts don't somehow become a force or become heat.
You have a sensor that produces so many millivolts per pound that is applied to it. You then want to scale that voltage so that it has a nice, convenient relationship.
Your output is not pounds (unless you have some actuator that is taking that signal and producing a load on something). You have a voltage that you want to interpret as indicating what load is acting on the sensor.
If you have 1000 lb as your input load, what voltage do you need in order for your meter or gauge or whatever you are using to indicate 1000 lb?
ericgibbs
Joined Jan 29, 2010
21,552
hi S,
Most electrical sensors give an output which is proportional to the parameter which the sensor is being used to measure.
For example:
a simple fuel tank sensor will give a electrical signal which is proportional to the amount of fuel in the tank.
As a human, if I was presented with a gauge that gave me the fuel level in millivolts I would have to mentally convert it into gallons or litres.
That would be a pain in the rear, as every vehicle I drove would probably have a different sensor, so by Scaling the sensor value, we normalise the display reading.
The display gauge is scaled so that I see a reading of gallons or litres.
E
satti15790
Joined Jul 17, 2017
17
hi S,
For example:
E
ok I got it... But in my case some example values are like this
Input : 785mv ----------------> output:280lbs
Input : 1131mv ----------------> output:670lbs
Input : 1880mv ----------------> output:1540lbs
As above you mentioned ur scaling will work only for last value... Can you make it generic? if Possible
I think u got my point?
Thanks in Advance
WBahn
Joined Mar 31, 2012
33,111
What kind of thing are you using that has a voltage for an input and produces a force as an output? Is it some kind of hydraulic actuator?
Whatever it is, your response is very nonlinear, so you need to characterize it to determine how best to model it.
What, exactly, is it you are doing?
satti15790
Joined Jul 17, 2017
17
We have some sensors which are related to Jet Fighter Aircraft...
Those sensors will give inputs to the Engine, from Engine we should read those and convert and Display,this is the actual procedure
Sample inputs from Sensors are Temperature,RPM,Fuel etc
If Fuel Sensor input is 785mV, then the output should be 280lbs...
Similarly as mentioned previous....
I hope u understood
Thanks in advance...
ericgibbs
Joined Jan 29, 2010
21,552
hi satti,
Are you saying that the fuel sensor is giving an output of 785mV for 280lbs 'weight' of fuel in a tank.????
IF the sensor output versus lbs weight was linear, you could say the sensor would output 2.66mV/lb.
but if the sensor versus lbs is not linear, you will have to determine the relationship, either by measurement or referring to the sensor manufacturers data.
We need much more information from you, in order to give meaningful advice.
E
satti15790
Joined Jul 17, 2017
17
hi satti,
E
Hi Gibbs thank you for your reply...
Ok let me explain in detail...
Sample flow of project
Sensors----->Controller(MSP430)-------->Display
So Controller will read some data from sensors and process the data and Send to Display
For Example Sensors will give some output 785mV to Controller, Controller need to process and give the output as 280lbs to Display
Here are some of sample sensor outputs
785mv ---------------->280lbs
1131mv ----------------> 670lbs
1880mv ----------------> 1540lbs
sensor output range (0 to 1880mV)--------------------->Data processing(0 to 1540lbs)
Customer not provided any sensor data sheet... These values are not linear
So if there is any possibility to make generic conversion for above values
Hope u understood...
ericgibbs
Joined Jan 29, 2010
21,552
hi s,
I follow what you are asking, the problem is that there are only 3 data points, not really enough to form an reliable equation.
Is it possible to post more data points.?
Is this project for a safety critical application or just a college assignment.??
E
satti15790
Joined Jul 17, 2017
17
hi s,
E
No, I dont have other data points... Customer provided only these data points
This project is not a college assignment... I am working for Aeronautical related company...
This project belongs to Fighter Aircraft...
WBahn
Joined Mar 31, 2012
33,111
With only three points you only have a few reasonable things. You can use a piecewise linear fit, you can use a quadratic fit, or you could try to do some kind of spline fit, though I don't know if three points is enough.
It sounds like you are trying to take a VOLTAGE signal out from your sensor and then drive some kind of display that will indicated in the proper units. What kind of display are you using?
But at one point you mentioned taking the signal from the engine, which got its signal from the sensor. Is the engine just buffering the signal and making it available to you?
Does anyone at this aeronautical related company have any electronics background?
satti15790
Joined Jul 17, 2017
17
---> Yup
It's like an back light LED Display...
I dont have any other data points....
Yes, the engine is just buffering the signal...
