I want to switch ON and OFF a 0.5 HP 230VAC motor (used for pumping water) with a relay module as shown in the image attached.
I plan to use a 9V battery to do so. The relay reads 'JQC-3FF-S-Z' and '10A 250VAC'. The motor's current rating is 3A. The module has other components apart from the relay. I'm assuming they prevent issues like back emf and arcing during switching.
Is it safe to use the module? If not, what do you suggest?
Thanks in advance.
![20170219_241039453_708x592.jpg 20170219_241039453_708x592.jpg](https://forum.allaboutcircuits.com/data/attachments/108/108561-033811983e4742125dffa46477969a87.jpg)
Thanks in advance.
