Hi Everyone,
I'm looking to make a light setup that uses 6 color LEDs, is powered by 12v and can be controlled by a PCA9685 and PWM. The LEDs I'm looking at are the following.
15W RGBWA+UV 6IN1 Led Beads, Led Chip, Led Lamp Bulb for LED Stage Lights
PCA9685 Datasheet
I've read a lot of different things that suggest a BJT transistor would be best, but I'm not very knowledgeable with transistors myself. Any tips or suggestions on what to use? It would need to be fast switching and be able to handle PWM.
Any help is appreciated.
Thank you!
PCA9685 Datasheet
Thank you!
