Control Line flying
beatsal
Joined Jan 21, 2018
425
I have a GWS Slowstick model airplane that I would like to fly by Control Line. Is there anyone who has done this -looking for some guidance.
SamR
Joined Mar 19, 2019
5,539
Control line is a whole nother ball of wax. First is the bell crank which is built very solidly into the root of wing and eyelets in the ribs of the wing and wingtip for the control wires. Also the engine and tail fin are angled so that even though the plane is flying in a circle it is actually pointed somewhat outward as if to leave the circle in order to keep tension on the control lines. Just a few of the hurdles to overcome as well as a fixed fully open throttle and the engine carbuerators are even designed differently.
MaxHeadRoom
Joined Jul 18, 2013
30,847
Also the control lines should form a line through the centre of gravity/balance point.
Mine was back in the days of full bore compression ignition.
(I even made my own fuel)
The Local chemist always quizzed me about the 1/2 gal of Ether I would order. o_O
beatsal
Joined Jan 21, 2018
425
This is a model for electric motor control but I don't have the motor/ESC, so like to try it first using CL. Never done this before so not sure what is req'd. If you can share your knowledge and/or refer me to a website, would be appreciated.
MaxHeadRoom
Joined Jul 18, 2013
30,847
I suggest you look at the plans/design of a typical CL trainer.
I imagine there should be quite a few out ther.
Take note of what has already been posted as to design features, regardless of plane model design.
You would need to set the ESC up for maximum prop RPM for most trainers.
Do you intend using it later for RC??
LowQCab
Joined Nov 6, 2012
5,102
A " Slowstick", or any model with the words "Slow" in their name,
are not good candidates for conversion to Control-Line flying.
Control-Line Planes are a very fast "brick" on the end of a string.
They really don't really qualify as an actual "Airplane", they just look similar.
The "Lines" create a tremendous amount of drag,
light-weight, low-speed, "Park-Flier" type Planes,
don't have enough Power, or Weight, to overcome the weight and drag of the "Lines" .
Purchase a "Flight-Simulator" that will allow You to fly on your Computer-Screen
using the actual RC-Transmitter that You have chosen.
Almost all RC-Transmitters have a "Trainer-Port" Output that is usually completely universal.
Make sure that your actual Model is square and straight,
and that the CG is located exactly where the manufacturer recommends it to be.
If the manufacturer has a range of CG-Locations,
start-out with the Plane being Nose-Heavy,
this will make the Plane more stable, and easier to fly.
KeithWalker
Joined Jul 10, 2017
3,621
What size motor are you planning on using? I designed and flew electric RC planes for many years, starting in the 80s. I tried control line but the electric motors and batteries didn't have enough power in the early days. I did make a SMALL successful "round-the-pole" plane that could take off and land using PWM power through the control wires.
This may give you some ideas:
https://www.stevensaero.com/product/ringrat-100-electric-control-line/
beatsal
Joined Jan 21, 2018
425
I have a diesel - a DC Merlin which I want to try on this, problem is there is no sevo available that can control engine speed or shut off.
MaxHeadRoom
Joined Jul 18, 2013
30,847
Not all fit that category, when I started there were some simple light trainers that you could fly with a 1.5cc 2cc motors.
It had to be very calm though. :oops:
SamR
Joined Mar 19, 2019
5,539
Steel lines, Fox .35, and a Flite Steak Stunter flying a stunt repertoire ain't exactly a "brick on a sting"! Now some of those Cox Plastic thingies were, if they even flew! Even a balsa and doped paper with a Black Widow .049 and some hot fuel was heaps of fun! I never made the transition to RC. Couldn't afford to, back in the day... I still have a Flite Streak Jr with an Enya .19 out in the garage.
