Continuity of Top capacitor to Negative Lead (Electorlytic Type)
nimrod.agno37
Joined Nov 17, 2017
I have read some of the query about leak on the top portion of the capacitors.
I am experiencing shorted measurement between Top portion of capacitor and Negative Lead.
This is normal?
Thank you,
dl324
Joined Mar 30, 2015
18,467
Welcome to AAC!
It's normal for the case on axial electrolytics to be the negative terminal, but not for radial.
philba
Joined Aug 17, 2017
959
Also, how are you checking continuity? If you use an ohm meter, a discharged cap will read zero initially as it starts to charge. Leave it long enough and the resistance reading will rise.
