One of my mechanical keyboard keys sometimes doesnt seem to work properly and I think its a contact problem. Could I use wd-40 as a contact cleaner?
Yes
What do i do then, i dont want to buy an new keyboardNO! WD stands for Water Displacer. It is not contact cleaner. Keyboards are pretty much considered throw-away items these days, unlike the old teletype keyboards they used to use.
Purchase recognized contact cleaner, you can get two types, those that leave a lube residue (oily) or non-residue type.
The keyboard is mechanical meaning that each key has its own switch and the contact is happening in those switches independently. So dissasembling the keyboard wouldnt helpAre we referring to a computer keyboard?
Show us a photo of the keyboard.
PC keyboards are usually made with membrane switches on layered sheets of mylar. Disassemble the keyboard and carefully and gently wipe the sheets with a swab of IPA (isopropyl alcohol).
If it does not fix the problem then the only resort is to buy another keyboard.
U | Transistor to act like a dry contact. | General Electronics Chat | 17 | |
Is there not_bad smelling contact cleaner ? | General Electronics Chat | 3 | ||
D | Contact Cleaner temperature | General Electronics Chat | 1 | |
WD-40 as contact cleaner...??? | General Electronics Chat | 10 | ||
M | Best practice: contact cleaner? | General Electronics Chat | 2 |
