Well when I say gasoline I meant as a preoil thinned mix. Gas/oil mix as an ease of lighting and to guickly build heat to sustain oil only fuel. I do have other ideas for the spark generator but this is my primary goal for it. I was playing with the idea of a heat coil embedded in the outer layer of fire brick but I do worry it'll over heat. it has occurred to me the blower I'm using, conveniently has a heating element on it. A few turns of tubing directly in front of it would heat the oil nicely. Though I assume hot air intake wouldn't be as effective as cold dense air.Why not a heat tape wrapped around the oil supply lines? That would heat the oil in the line and may give it enough to start easier. The flash point is pretty low, "Number 2 fuel oil has a flash point of 52 °C (126 °F)"
From, https://en.wikipedia.org/wiki/Heating_oil
Or start on Kero and switch over after heat is built into the furnace. I'd never use gasoline.
