complex number
pot
Joined Nov 9, 2015
9
hi
how I can collect this number use my hand and calculator "fx-991ES"?
complex number
e^0.00931 e^j0.3730 in radiant
22,116
There might be a missing symbol in the expression. The first number is a plain or real number.
\(e^{0.00931} = 1.009\)
For the second expression you can use the Euler Identity
\(e^{jx}=cos(x)+j sin(x)\)
x is in radians
33,111
hi
complex number
Can you do it without a calculator? Or are you relying on the calculator being a brain substitute?
You calculator supports polar entry of complex numbers. Converting your expression above to polar is trivial
Magnitude = e^0.00931
Angle = 0.3730 radians
Look at your owner's manual for how to enter the values:
http://support.casio.com/storage/en/manual/pdf/EN/004/fx-115_991ES_PLUS_C_EN.pdf
Look on page 25.
