Complex Impedance and Polar Form
pianolife
Joined Nov 15, 2012
28
Dear members of all about circuits, I've got a question about Complex impedance and polar form.
I've read it in your ebook, and I'm practicing with some exercises. But here I am asked to write a kind of "general" formula, without values, and I just wanted to ask if this is correct.
The task is:
What is the impedance Z between terminals A and B of the networks shown below? Express your answers in polar form.
Attached there is my answer.
Thanks in advance.
All the best and happy new year!
33,028
Here is were checking the units comes into play.
You final answer is Z1/Z2. What are the units on this? Nothing - it is dimensionless. But you are looking for an effective impedance, so your answer has to have units of impedance (namely ohms), yet it doesn't. So you KNOW this answer is incorrect.
Always track your units throughout the work.
Always verify that the units work out.
Always ask if the answer makes sense.
33,028
I haven't walk through your work in detail, but you appear to be mixing two different definitions of capacitive reactance.
Some people, particularly those that don't ever deal with complex impedance, like to define both inductive and capacitve reactance as positive values and then memorize a bunch of formulas that have minus signs here and there. The better way to deal with this is to simply define reactance as the imaginary part of the complex impedance.
The impedance of R, L, and C are
Z_R = R
Z_L = j\omega L
Z_C = \frac{1}{j\omega C} = j \left( \frac{-1}{\omega C} \right)
The reactance of each is then simply
X_R = 0
X_L = \omega L
X_C = - \frac{1}{\omega C}
This lets you work with the generic notion of reactance and relieves you of having to remember whether to use a minus sign in your formulas depending on whether a particular reactance happens to turn out inductive or capacitive -- the sign is carried as part of the reactance value itself.
pianolife
Joined Nov 15, 2012
28
You are right, WBahn, I don't get which way would be easier (or more efficient) to work out this problem...
Talking with the lecturer, he would use jΩ's values, but the further I go, the messier it gets... I mean, I get to a point when I could multiply the denominator of the fraction for its complex conjugate, in order to get a real number, at least in the denominator.
But all this work seems really confusing, even if it is eventually right.
33,028
I firmly believe that it is better to let a reactance be a reactance and be done with it. If it happens to be negative, then it is capacitive and vice versa.
So for this network we have
Z_T = Z_1 || Z_2
\text{where}
Z_1 = R_1 + jX_C
Z_2 = R_2
\text{thus}
Z_T = \frac{Z_1 Z_2}{Z_1 + Z_2}
Z_T = \frac{(R_1 + jX_C)R_2}{R_1 + jX_C + R_2}
Z_T = R_2\frac{R_1 + jX_C}{(R_1 + R_2) + jX_C}
\text{putting the numerator and denominator in polar form}
Z_T = R_2\frac{\sqrt{R_1^2 + X_C^2} \angle \tan^{-1} \left( \frac{X_C}{R_1} \right) }{\sqrt{(R_1 + R_2)^2 + X_C^2} \angle \tan^{-1} \left( \frac{X_C}{R_1+R_2} \right)}
Z_T = R_2\sqrt{\frac{R_1^2 + X_C^2}{(R_1 + R_2)^2 + X_C^2} } \angle \left[ \tan^{-1} \left( \frac{X_C}{R_1} \right) - \tan^{-1} \left( \frac{X_C}{R_1+R_2} \right) \right]
\text{now you can substitute in}
\text{to get}
Z_T = R_2\sqrt{\frac{R_1^2 + {\left( \frac{1}{\omega C} \right)}^2}{(R_1 + R_2)^2 + { \left( \frac{1}{\omega C} \right) }^2} } \angle \left[ \tan^{-1} \left( \frac{-1}{\omega R_1 C} \right) - \tan^{-1} \left( \frac{-1}{\omega (R_1+R_2)C} \right) \right]
\text{It's important to note that the angles are in the fourth quadrant, not the second.}
\text{You can play a number of games to rearrange this in order to highlight one aspect or another. For instance:}
Z_T = R_2\sqrt{\frac{1 + (\omega R_1 C)^2 }{1 + (\omega (R_1 + R_2) C)^2} } \angle \left[ \tan^{-1} \left( \frac{-1}{\omega R_1 C} \right) - \tan^{-1} \left( \frac{-1}{\omega (R_1+R_2)C} \right) \right]
pianolife
Joined Nov 15, 2012
28
Wow! Thank you so much WBahn, I wasn't expecting such a huge help! Thank you so much!
Since it looks like you are really "on the ball" with this subject, I am just guessing if is worthy substituting (R1+R2) with Rtot.
Just, possibly, to make it more "legible"...
Thank you very much, I owe you at least a pint :D
33,028
You can, but then you have to be sure to clearly define what Rtot is. Don't assume that "it's obvious" -- the correct name for obvious things that aren't define is "undefined"! :D
