I'm using the AT91SAM7X512 device.
I have no idea which compiler to use in order to compile C code for the ARM7TDMI that's within the AT91SAM7X512 device.
I've read in many websites about Keil software but it confuses me even more.
What C class & corresponding header should I use for this device?
Also, how can I implement the binary code into the processor? Via JTAG? Which pins should I connect?
And there's a paradox in the AT91SAM7X512 datasheet: at first they say that the FLASH memory size is 512KB, later on (in the memory mapping page) it's 1MByte.
I'm totally frustrated.
Best regards,
Dor.
Edit:
Here's the relevant datasheets etc.: http://www.keil.com/dd/chip/4613.htm
Best regards,
Dor.
Edit:
