comparators lm399 not working
Fanfire174
Joined Mar 13, 2018
240
Hey guys,
I have a question about comparators I have 230 to 9v step down transformer and lm339. I want to compare positive and negative voltage. Does anyone know of a LM399 IC ?
Input voltage is 230v AC for transformer. I measure the output voltage of transformer is 8.5 aprpx
I have given 5v Dc supply to pin number 3 of IC and pin 12 is connected to ground
positive of transformer connected to pin 5
Negative of transformer connected to pin 4
I am measuring output voltage of comprator 1 but it show only 0 volt. Why it is not showing output voltage
27,708
No.
What does it do?
The LM339 has an open collector output.
It requires a pull-up resistor (say 10kΩ) from the output to V+.
Do you have that.
One of the inputs needs to be connected to ground (can be through a resistor) so there's a path for the input bias current.
Note that the input should no go below ground or above the supply (5V) or you may zap the device.
Thus you need to connect the transformer through a resistor and clamp the inputs (such as with diodes to ground and the +5V).
Fanfire174
Joined Mar 13, 2018
240
No.
Have you looked connection between transformer and LM339 ?
I have different size of resistors. I have 4004 diodes
I did just one change I have connected 12 k resistors at + input and - input of LM339
Can we give 10 V AC signal with 12k resistor to LM339
Dodgydave
Joined Jun 22, 2012
10,050
Hey guys,
Supply pins are pin 3 Positive, pin 12 Negative, i dont see any supplies?
24,170
1) LM399 is a precision voltage reference. LM339 is a quad comparator.
2) LM339 has open-collector outputs and requires a resistor from output to Vcc, as @crutschow already stated.
3) Use an optocoupler as @danadak has suggested.
Fanfire174
Joined Mar 13, 2018
240
I connected 10K from output to Vcc. I am getting 2.1 v Dc at output but I need 0v and 5v DC
you mean I have to use optocoupler instated comparator
danadak
Joined Mar 10, 2018
4,057
The optocoupler is largely for safety reasons.
The 2.1V is really quite out of spec if comparator is driving low. Spec is 400 mV off its
- rail sinking 4 mA which is much higher current than you are asking for. Very suspicious
of either part is good or is your 10 K actually 100 ohms.
Regards, Dana.
Fanfire174
Joined Mar 13, 2018
240
Regards, Dana.
Please take loot at this connection. when I measure the output voltage at optocuole 4n33 between pin 4 and pin 5. It is 5v DC
Fanfire174
Joined Mar 13, 2018
240
Regards, Dana.
Please take look at this connection. I measure the output voltage at optocuoler 4n33 between pin 4 and pin 5. It is 5v DC
