Common Mode Voltage In Power Inverter
enes246
Joined Nov 30, 2016
10
Hi everyone,
There are a few titles on the form about this topic, but But I did not fully understand this issue especially in the field of power electronics.
What is the common mode voltage?
what is the clear or very simple definition of it?
Why do we need desciribe common mode voltage?
Also why the formula of Common mode voltage is (V1+V2)/2?
Where does this formula come from?
Can I choose any place as a common point? or do I have to choose ground as a common mode point?
Thank you for all the answers
best regards
38,595
As the name implies "common-mode" voltage is the voltage that's common to more than one line (typically a differential pair) to the circuit common (ground).
Common-mode voltage can disrupt the normal (differential-mode) signal so it's important to know its value and whether the circuit can ignore this voltage (its common-mode rejection).
It should be apparent that the formula (V1+V2)/2 gives the common voltage to the two differential signals V1 and V2.
Thus, for example, if V1 =2V and V2 =3V then the differential-mode (desired signal) voltage is 1V and the average common-mode (undesired signal) voltage is 2.5V.
enes246
Joined Nov 30, 2016
10
Hi Crutschow,
I am very pleased with your encouragement, thank you so much.
But, there are still I do not understand clearly. :(
How do I choose the common mode point?
thank you so much.
38,595
The common mode voltage is referenced to circuit common as I previously stated.
What do you mean "choose"? :confused:
Why not?
The common-mode is the voltage that is common to both V1 and V2 and that is the formula to calculate it.
What formula would you use?
enes246
Joined Nov 30, 2016
10
Why not?
Thank you for answer:).
it is ok so, Is there a common mode voltage in every circuit?
I mean that how can I determine the circuit common because I conufuse that some aplication espacialy inverter aplication I sow the circuit common is mid point of two capacitor or netural point of DC source.
How can I prove the formula?
38,595
No, only for circuits with two inputs or outputs.
In switching power supply circuits there can also be common-mode current between the input and/or output and common (that is current flowing in the same direction in both lines).
This is sometimes suppressed (to reduce EMI) with a common-mode choke connected in series with the signal line and the common line, which readily allows differential (normal) currents to flow but has a high inductive impedance to the common-mode current.
enes246
Joined Nov 30, 2016
10
Thank you for all the answers you gave me.I think I started to understand :)
