Combined wire gauge
minh
Joined Nov 24, 2010
41
Dear All
I want to rewind an electromagnet original 21 wire gauge ( length 20 meters ) .
If I use 2 x 24 gauge instead of 21 wire gauge force of electromagnet will change (increase or decrease ) or same. Many thank you
38,952
Since two 24Ga wires in parallel have essentially the same resistance as a single 21Ga wire, then there should be no difference if wound with the same number of turns.
Ian0
Joined Aug 7, 2020
13,317
I much prefer measuring wires in square millimetres. That way I don't get caught out by duff AWG->mm^2 tables.
minh
Joined Nov 24, 2010
41
Dear sir
Thank you for your help . Can you help me know more question:
In two ways to wrap the wire what is better
1: 2 wires wrapped together at a time
2: wrap only 1 wire at a time after solder 2 wire in parallel
Thank you so much
KeithWalker
Joined Jul 10, 2017
3,628
Dear sir
Thank you so much
Wrap both wires at the same time, that way you will get the same number of turns of each and the ends will be together when you finish
