Coil inductor calculation
MentorEngima
Joined Oct 5, 2017
10
AlbertHall
Joined Jun 4, 2014
12,653
It all depends on the form factor of the coil.
What diameter is the coil to be?
Are you close winding the coil (each turn tightly next to the previous turn)?
MentorEngima
Joined Oct 5, 2017
10
0.26 inches or 6.55mm, each turn is close to another by slight distance (0.4mm), i winded the wire on a 0.25 inch bolt.
AlbertHall
Joined Jun 4, 2014
12,653
All those formulae give number of turns around 3 to 4. As you can't really do a coil of 3.6 turns probably the best way is to use 4 turns and then measure the inductance and stretch or squish the coil to get the desired value.
