So you are attempting to upgrade your CNC by going to a bigger motor?is there a middle device i can go from output of ortur motor connectors to DM542T driver
then to bigger stepper motors
oh the power supply is like 60 volts on the big motors and the little motors are 24 volts big differencehttps://www.madethebest.com/product...cM5pOx4dW35CeBGtdzmyhy40lFowTVzhoCllwQAvD_BwE
DM542T driver to run nema23 stepper motor for making my own router cnc
I've never heard of going from one driver to another the one in the link above is controller wit built in driver for controlling the nema17 stepper motors and i want to convert that driver back to something the DM542t driver can understand and then to the nema24's
i was wrong here's the link to the motoroh the power supply is like 60 volts on the big motors and the little motors are 24 volts big difference
The power supply would not be able to drive two motors.That motor is 4.2a which is cutting it close!
BTW NEMA rating is a physical mounting size, not an exact indication of power.
yes that's what i thought needs fast switchingYou might end up losing the close control of a direct coupled amplifier/drive.
