I have recently installed a Click PLC with a 4-20ma card and (2) Thermocouple cards. I have 4 pump temps being read with K type thermocouples and then 4 channles ive twisted the K type wire on them for future use. The problem I am having is with the pumps. Friday all my temps were dead on and reading perfect. The 4 pumps were turned off and not running due to a plant shutdown. Today I come in and my temps are reading around 200f on one set of pumps (2&3) and the other set (7&8) pumps are reading around 400. pump 3 and pump 7 are running the others are backups. If i unplug the pumps that are not running and plug in a thermocouple into my pre-extisting wire run it works great. But if i touch the pump with the thermocouple ive plugged in externally it it goes crazy again. I have made sure the pump is grounded good and can not read any voltage on the pump frame (MV or AC). It is just pumping chilled water FYI. its like I'm getting noise but i cannot see it. The K-type wire is not shielded and the Click PLC is configured right for K-type. Keep in mind its only on the pumps that are not running and the 4 runs of K-type wire is all ran the same way into the same box.I've ran new wire outside the box and have the same issues. It's something with the pumps. They are driven by a GS2 automation direct drive.The power is off to the drives that feed the pumps that are not running as well. Any ideas would be appreciated.
