Circuit schematic for project
Moshkes
Joined Oct 19, 2024
Please help me. Screenshot_20241019-102853_Word.jpgI need to draw a schematic in any compatible soaftware that close to enough to pspice as it can be and if possible to upload the file here. The schematic is of a system consisting of two parts:
In the first part, there is a development board compatible with Arduino Seeeduino XIAO nRF52840 Sense (unsoldered) that is connected to a power source through the usb typw c xoneection and connected to a push up button that for every time the button been pressed the Arduino Seeeduino XIAO nRF52840 Sense (unsoldered) send a signal via the built-in Bluetooth to another development board compatible with Arduino Seeeduino XIAO nRF52840 Sense (unsoldered) located in a white cane in the second part for 30 second and then stop unless the push up button has been pressed again. The signal sent via the built in Bluetooth is limited up to 10 cm.
In the second part, in the white cane, there is a development board compatible with Arduino Seeeduino XIAO nRF52840 Sense (unsoldered) connected to a rechargeable lithium battery 3.7V with a protection circuit 18650 as a power source, and also connected to a vibration motor - Grove connection. When the development board in the second part receives the signal from the development board in the first part via the built-in Bluetooth, the development board in the second part activates the vibration motor. The vibration motor operates as long as the development board in the second part receives a signal from the development board in the first part. The entire second part is inside the white cane.
I add how it looks. It not very clear but still a thing. If pspice not possible Kicad is a second choise.
