Circuit design of a photodiode
pooya_b
Joined Feb 25, 2021
59
hi pooya,
This is one example showing how to reduce the falling edge of the amplified pulse.
Control the Vbias On/Off time and polarity, you will need a fast OPA to create the pulse.
Modify it to suit your project.
Image shows the original version and the modified Vbias for comparison.
E
hi
Do you think this circuit is suitable for my work?
I saw the circuit you sent, I think you misunderstood what I meant. I do not want to just have a whole square wave. The way you said it was great.
I have more to have accurate waveforms. That means I need to have exactly the right waveform.
ericgibbs
Joined Jan 29, 2010
21,649
hi p,
It is not possible for me to say if that is suitable, I do not know the exact specification of the pulse you require.?
I would need more details of the project design specification.
I understood from your earlier posts you just required a fast Off time for the pulse.
What was the purpose of posting that circuit from Analog Devices.?
E
pooya_b
Joined Feb 25, 2021
59
hi p,
E
It is better to say that I do not need a quick shutdown.
In that example, it was clear that the photodide did not have the correct shutdown time and would turn off very slowly.
I want the photodiode to give me a real time pulse and event.
Most of my work is on measuring life time phosphorescence. If the photodiode has a lot of fall time, I can not do exactly this test.
ericgibbs
Joined Jan 29, 2010
21,649
pooya_b
Joined Feb 25, 2021
59
hi pooya,
The response curves of these two devices are longer than the values you are requiring [ based on your original images]
E
What parameters do you think I should consider to choose a suitable amplifier for my work?
Some datasheets do not say photodiode for use. Is this type of amplifier suitable or not?
Please help me find a suitable amplifier.
pooya_b
Joined Feb 25, 2021
59
hi pooya,
E
Hello
Please, if you can tell me what parameters are suitable for my photodiode that I should pay attention to when choosing an amplifier.
I have already realized that I have to use transimpedance amplifiers.
Please help me choose the frequency and bias current.
pooya_b
Joined Feb 25, 2021
59
Hello, I appreciate your help.
Currently, I am away for a few days. I will test it afterward and let you know the result. I have a question for you : Do you think it is better to use OTA or TIA amplifier? I have got seperate suggestions to use both of them but I can not make a decission which one is suitable.
I am sending you names of some amplifiers that I have in access. Please let me know which is more suitable for SFH 2704 photodiode.
ericgibbs
Joined Jan 29, 2010
21,649
hi p,
The 'best' from those 4 OPA's is the OPA354, even that one will not meet your pulse rise and fall time requirement.
I would choose a Trans Impedance design
E
Update: added PDF
pooya_b
Joined Feb 25, 2021
59
hi
I also want to use a second amplifier and increase the output of the first amplifier so that I can have an output of about 2 volts. Do you think I can use AD 8042 friends?
Here I put the simulation for you.
