choosing a comparator after simulation [SOLVED]
anishkgt
Joined Mar 21, 2017
549
Hi All,
i've just simulated a comparator on LTSpice and it seem to get what i expected. Now i wish to know if there would be any change in the way the comparator would work when using an LT1018 and a MIC7221YM5-TR. The LT is a bit too expensive compared to the Microchip.
My circuit is a comparator as seen below.
Thanks in advance.
danadak
Joined Mar 10, 2018
4,057
You can answer that by doing a quick comparison of data sheets.
I would look at input CM range, speed, output I drive, output CM range,
supply ratings, offset as a first order comparison.
Regards, Dana.
ericgibbs
Joined Jan 29, 2010
21,423
hi anish,
I would say that the MIC would work OK in that circuit, note the +10V limit on Vsupply.
E
EDIT:
Post your LTS asc file.
eetech00
Joined Jun 8, 2013
4,705
Initially the led will light up at 16.8 and will stay ON till it reaches 24v or close to it.
Hello
This is what a simulation of your circuit produces:
So...you only want the LED on from 16.8v to 24v?
Then it will need a window comparator...
Is the whole circuit going to run from the battery?
eT
anishkgt
Joined Mar 21, 2017
549
Yes it would be running from the battery only. The idea is to detect when the battery goes below 16.8v, that would be 2.8v/cell and that would light up the LED as an indicator that the pack has gone beyond the set voltage.
eetech00
Joined Jun 8, 2013
4,705
o_Oumm...ok..
You stated yes...(indicating you want the LED on from16.8-24v) but you now state you want it on when the battery is below 16.8 volts..:confused:
Which one is it?
anishkgt
Joined Mar 21, 2017
549
o_Oumm...ok..
Which one is it?
Sorry about the confusion, the LED will light up when the voltage hits 16.8v and will stay on till it reaches 24v.
