Choice of shunt resistor and measurement resolution
engr_david_ee
Joined Mar 10, 2023
364
I am using INA3221 bus and shunt monitor.
The following info is taken from datasheet.
Shunt Voltage (Vshunt) = -163 mV to +163 mV
1x LSB Shunt Voltage = 40 uV
1x LSB Bus Voltage = 8 mV
Differential Nonlinearity = +/- 0.1 x LSB
Shunt Voltage Gain Error = 0.1 % to 0.25 %
Bus Voltage Gain Error = 0.1 % to 0.25 %
I have two current requirement mentioned below. I need to measure currents and bus voltages using INA3221 which is triple channel bus and shunt monitor.
Requirement 1: Load voltage 2.75 V and load current 3.6 A.
Shunt Resistor = 39 mOhm
Shunt Voltage = Shunt Resistor x Current = 39 mOhm x 3.6 A = 140 mV
Power of Shunt Resistor = Shunt Voltage x Current = 140 mV x 3.6 A = 0.5 Watt
Current Resolution = ADC Voltage Resolution / Shunt Resistor = 40 uV/bit / 39 mOhm = 1.02 mA/bit
Requirement 2: Load voltage 3.00 V and load current 10 mA.
Shunt Resistor = 14 Ohm
Shunt Voltage = Shunt Resistor x Current = 14 Ohm x 10 mA = 140 mV
Power of Shunt Resistor = Shunt Voltage x Current = 140 mV x 10 mA = 0.002 Watt
Current Resolution = ADC Voltage Resolution / Shunt Resistor = 40 uV/bit / 14 Ohm = 0.003 mA/bit
Kindly let me know if I am missing anything in current resolution.
