Cheap fan control without microcontroller
RodSTAR
Joined Jan 3, 2008
15
Hello electronics guys, I want to turn on an AC or DC fan when a heatsink reaches a certain temperature determined by a potentiometer, and then fan speed to be some quite proportional to temperature. I bet or I'm sure this situation has already been solved anywhere anytime, but I want to know where to find the circuit or if is there already any cheap kit (on eBay or something) to do this. I could easily do this with a microcontroller, but I want some cheaper solution.
Regards
MaxHeadRoom
Joined Jul 18, 2013
30,810
A simple 12f series pic could do this fairly cheap.
You would need a thermal sensor also and the output device would depend on the nature of the motor.
Max.
ian field
Joined Oct 27, 2012
6,536
Regards
ATX PSUs used to have a neat little sub panel with a couple of transistors and a thermistor on a fly lead clamped to the heatsink.
Nowadays its fully integrated into the main PCB - but if you can be bothered hand tracing the circuit.
Its a good basis for the control circuit, you can buffer the output for what current you need.
