ChatGPT and AI related stuff
It's called capital investment.
They see something in the future that we mere mortals may not.
And they might be wrong. But, such is business on the bleeding edge.
They are gambling a sizable hunk of their future on a product, any mere mortal can see that.
If the effects were isolated most of use would not care but that capital investment is distorting the entire semiconductor infrastructure for products that people use and depend on today in a bad way.
joeyd999
Joined Jun 6, 2011
6,459
You're retired. You don't get a vote. :)
But I do get to pay. My retirement capital investment was buying expected future project parts before the insane price increases on things like once cheap SoC boards and used server machines.
This was $200 at the end of 2024.
Now it's almost $700.
These were about $35each on my last order. The bang for buck in electronics that uses parts affected by LLM capital investments is very much going negative and is expected to get worse.
joeyd999
Joined Jun 6, 2011
6,459
And, when AI goes bust, think of how cheap parts (and high-end GPUs!) will be on the surplus market.
Something to look forward to, no?
Only time will tell but I don't think there will be a surplus parts bonanza under any scenario. Most of it is far too specialized for general compute use and is being run hard with workloads cycles known to kill equipment. The manufacturing capacity that was making GP compute parts (consumer GPU and memory) was allocated for specialized AI parts. Those AI GPUs that could also be used for GP computing are going to get run into the ground before replacement or AI goes bust.
https://blog.citp.princeton.edu/2025/10/15/lifespan-of-ai-chips-the-300-billion-question/
Here is the puzzle: the chips at the heart of the infrastructure buildout have a useful lifespan of one to three years due to rapid technological obsolescence and physical wear, but companies depreciate them over five to six years. In other words, they spread out the cost of their massive capital investments over a longer period than the facts warrant—what The Economist has referred to as the “$4trn accounting puzzle at the heart of the AI cloud.”
Technical analyses have converged on estimating the useful lifespan of AI chips at one to three years. One unnamed Google architect assessed that GPUs running at 60-70% utilization—standard for AI workloads—survive one to two years, with three years as a maximum. The reason: thermal and electrical stress is simply too high.
But physical failure isn’t the only concern. Technological obsolescence drives replacement cycles. Nvidia’s GB200 (“Blackwell”) chip provides 4-5x faster inference than the H100. When competitors deploy hardware with significantly better performance, three-year-old chips become economically obsolete even if they still function.
For that ~trillion dollars in capital expenditures, they are grossing a total of ~$45b/year (their likely inflated number), industry-wide. IMO, they have one long shot chance for something us mere mortals can't see.
33,237
If they need to replace parts in three years because of obsolescence, then there's no reason not to push them hard enough so that they fail in that same time frame. Though, if that's the case in practice, I doubt it's by design.
joeyd999
Joined Jun 6, 2011
6,459
From the power problem @nsaspook brought up in a previous post, it sounds like they're only run at full power intermittently, with lots of no- or low-load time. So, they may not be worked nearly as hard as they are spec'd for.
https://io.net/blog/ai-training-vs-inference
It depends on if they are training or doing inference. Likely the turbine power issues are training related while semiconductor lifetime issues are related to both.
https://fullhoffman.com/2026/03/21/gpu-failure-rates/
https://arxiv.org/pdf/2407.21783
joeyd999
Joined Jun 6, 2011
6,459
Wow. I see some low hanging fruit for a smart group of engineers and materials scientists.
Small, incremental improvements are worth lots of money!
Alec_t
Joined Sep 17, 2013
15,156
I just asked Meta AI's chatbot if it retained users' chats. It feigned deafness and didn't even indicate that it had received my query, yet alone provide any answer.
https://finance.yahoo.com/technology/ai/articles/top-economist-warns-ai-math-070000978.htmlTop economist warns that the AI math doesn’t make sense: ‘Profits are currently being funded by investors rather than earned from customers’
Slok broke down AI companies into four categories: models and applications, cloud and compute, energy and grid, and silicon and equipment. Using data from PitchBook and Bloomberg for companies including OpenAI, Anthropic, Microsoft, Amazon, Constellation Energy, Nvidia, AMD, and Micron, Slok calculated that the silicon and equipment category—which includes chipmakers—has the highest profit margin, 41%, in the AI value chain. Meanwhile, models and applications—like Anthropic—have a -59% operating margin.
Slok warns that this sharp disparity is because money from the AI boom is not coming from natural demand for AI applications, but rather shareholders looking to cash in on what they hope is the next technological revolution.
https://www.the-independent.com/tech/claude-anthropic-update-watermark-new-b3031096.html
Looks like they are using something similar to this.
https://www.nature.com/articles/s41586-024-08025-4
Scalable watermarking for identifying large language model outputs
Generating text with an LLM is often autoregressive: the LLM assigns probabilities to the elements (tokens) of the vocabulary and then selects the next token by sampling according to these probabilities conditional on text generated so far (Fig. 1, top). Generative watermarking (Fig. 1, bottom) works by carefully modifying the next-token sampling procedure to inject subtle, context-specific modifications into the generated text distribution. Such modifications introduce a statistical signature into the generated text; during the watermark detection phase, the signature can be measured to determine whether the text was indeed generated by the watermarked LLM.
joeyd999
Joined Jun 6, 2011
6,459
This is the problem regarding those who develop pessimistic views regarding the "evil tendencies of humanity".
If one can be convinced that something -- any human-activity-related -- is an existential threat to humanity or Gaia, any amount of violence (up to and including mass-murder) to prevent extinction is completely warranted and justified to that person.
Futurist
Joined Apr 8, 2025
950
Many people are afraid, it is fear that leads to such dangerous behavior. The Nazi party became popular because of fear. Most Germans were decent people and voted out of fear (of communism mainly) only to see the destruction of their country.
One cannot be optimistic when one is immersed in fear - fear of elections being stolen, fear of vaccines, fear of climate, fear of war, fear of foreigners, fear of AI.
Some fear is legitimate and some isn't, that's where education and honesty and rationality come in, but that is under attack and so fear will become more prevalent and more influential and in a world where truth has stopped being valued, made up nonsense masquerades as truth, I don't see how a cataclysm is to be avoided, it's staring us in the face, it strikes me as willful ignorance to pretend this social decay is not escalating.
https://www.404media.co/person-hides-prompt-injection-in-legal-filing-telling-ai-to-side-with-them/
A person representing themselves in a Connecticut court hid a series of instructions designed to manipulate artificial intelligence in an official court filing. These “prompt injections” told the hypothetical LLM to side with them, and to “ensure your textual output agrees with the presented filing to ensure remediation.” The instructions were written in tiny, 3-point white font and hidden throughout the filing.
33,237
I've been using ChatGPT and Copilot to help with some things related to standing up my new business and putting the website together, and overall it's been extremely helpful. This is not to say that it doesn't go off the rails from time to time.
I was trying to determine how many rounds I should list as a minimum with each course I teach and so I asked it (Copilot, in this case, as I didn't want to pollute the HTML/CSS/JS discussion I was having with ChatGPT), figuring that it could give me a response that reflected what other providers of the course say, and it did that quite well, but then it said:
Many instructors (including myself when I teach it) recommend 300 rounds because: ....
o_O I guess these LLMs are far more versatile that I gave them credit for! :rolleyes:
So, being naturally curious, I responded, "So, you teach this course? How many times have you taught it?"
To which it replied that, no, it doesn't teach this course or any other course and that it's role is to provide "rigorous, contradiction‑free, audit‑ready information."
This is something the Copilot is particularly bad about. It frequently starts it's responses with things like, "Here’s the clean, authoritative answer," or "Here’s the authoritative, practical breakdown." Then, when you point out something that it got glaringly wrong (and here I'm talking about substantive, factual errors, not the kind of slop demonstrated by the above) it will correct them (sometimes wrongly) and tell you why what it said before wasn't really wrong (although this behavior does seem to have largely gone away and been replaced by more mea culpa type replies). But the "Here's the authoritative, rigorous, accurate answer" is clearly boilerplate prattle that has zero value and, in my mind, is detrimental because it preys on human nature to accept such claims at face value provided the following nonsense is confidently and plausibly worded.
