Ceres
Alec_t
Joined Sep 17, 2013
15,158
Interesting.
Is it just me, or an optical illusion, but the terrain around the mountain seems to be littered with raised circular bumps rather than craters?
oz93666
Joined Sep 7, 2010
742
After WWII many Germans escaped to a base in Antarctica , where they continued developing UFO type craft , Were first to the Moon and built a small base , then moved on to Ceres one of the larger bodies in the asteroid belt ...
"...Ceres Colony is a network of cities and bases underneath Ceres that is controlled by the Germans. This network is interconnected by two rings of subterranean train systems. Inside the cities are rows of old, European-styled brick buildings bisected by a small road for police and emergency vehicles. There is even a red-light district in one of the cities. The Germans live in mansions somewhere within Ceres.
Slave labor is widespread in Ceres Colony. As of 2001, its population is 225,000, 40,000 of which are slaves. Their living quarters are prisons which hold 5,000 men each. Each resembles the Alcatraz Federal Penitentiary, except the cells do not close. The slaves are responsible for manual labor on Ceres and aboard ships. One of their duties is mining. The slaves cleared debris as a high-powered laser drills through the rock. Although the Germans make use of everything that was mined, the main objective of mining is to find water-filled caverns. They make favorable places to build a city or a base once the water has been emptied out.
There are ET races that visit Ceres Colony as well as races that work there. All of the shops within Ceres Colony are managed by a 9-ft. tall race, possibly the pre-Adamites. One race with elongated skulls and slanted foreheads is often consulted to repair vehicles and equipment; they are natural technicians.
There are several hanger doors around Ceres. One is located in a crater near Ahuna Mons and leads to Pyramid Base.
Ceres Colony has its own military which forms a component of what has been called the Dark Fleet.
The head of Ceres Colony ranks under a beige royal Draco, who he reports to within a temporal anomoly around Jupiter.
History
The Germans discovered that an extensive series of underground caverns underneath Ceres had been colonized and later mothballed by extraterrestrials. The Germans, along with a couple ET races, re-settled and expanded this network. Many new caverns were hollowed-out and occupied. Judging by the rust and dilapidation in some areas, construction appears to have begun in the 1940’s.
One of the areas the Germans discovered was a room miles underground full of moving trapezoidal slab doors with neural-interfacing technology. They retrofitted it into a metal apartment. This is where Tony Rodrigues stayed during his service as a slave. They installed a very long elevator connecting it to Ceres Colony above....."
Berzerker
Joined Jul 29, 2018
623
@oz93666
And @nsaspook thought I was crazy for saying Aliens weren't real and it was just our or someone else's government with new technology.
But post #4 is way beyond anything my mind could ever fathom. If you believe this guy I got a piece of Saturn I need to sell. You might as well believe all the time travel, Alien/Human breeding, Bigfoot, Ghost, Werewolf "NUTS". Come on...... Nazi's on Ceres:confused:, Strip Clubs, Prisons, Slave labor, Alien tech,,,,,,Yeah right.
Brzrkr
AlbertHall
Joined Jun 4, 2014
12,653
The shadows associated to those circular bumps, make me conclude that light has only one option: to come from the upper right side in the picture.
But if you can persuade your brain to see the scene with the light coming from the lower left side then they become craters.
KeithWalker
Joined Jul 10, 2017
3,621
If you take another look at the illustration, you will see that the light is shining on the left side of the mountain, so unless someone changed the rules without telling me, it will be shining on the craters from the same side.
Berzerker
Joined Jul 29, 2018
623
I can't believe it. Someone says their are Aliens on Ceres and Nazi's, Strip Clubs, Prisons and Slave labor and all you say is....... Light tricks??
Back to the "Face on Mars" :p:confused::confused:o_Oo_O
It's just a weather balloon, Atmospheric reflections...Boy!
Brzrkr
jpanhalt
Joined Jan 18, 2008
11,087
Brzrkr
It's on You Tube, owned by Google. Must be true.
Berzerker
Joined Jul 29, 2018
623
I've posted about my non- belief in Aliens visiting Earth all over this forum. But post #4 got me is where I'm at. That crap is outta this world..... get my drift.
Brzrkr
BR-549
Joined Sep 22, 2013
4,928
I thought the structure was different. And was always hoping to find the un-exspected in the belt.
But, it just goes to show, that one can't keep up on everything.
KeithWalker
Joined Jul 10, 2017
3,621
It must be true because it's on the internet!!! If you look really hard you can see part of a swastika right at the top of the mountain.
BR-549
Joined Sep 22, 2013
4,928
You know, I think you're right. They tried to camouflage it from the telescopes........but it's there.
