CE Amplifier
eis4497
Joined Jul 6, 2019
16
I am trying to figure out how a CE amp works. I put a circuit that I found in a spice sim
program. The voltage gain by hand calculation is 1.2K / 220 + 22 = 3.52. With a 1 mV
1 khz sine input, the output is about 120mV. Why would this be?
dl324
Joined Mar 30, 2015
18,328
You'll get more appropriate answers if you show us the schematic for the circuit so we can see where those numbers are coming from.
eis4497
Joined Jul 6, 2019
16
Sorry. meant to show you the schematic.
Oh. And the output wave starts in a weird place. Like at -120 mV instead of zero.
eis4497
Joined Jul 6, 2019
16
Where did these numbers come from? How did you get 3.52? As written, the result is 27.45.
This is how I arrived at the gain.
r'e = 25 mV / IE = 25 mV / 1.13 mA = 22.1Ω
Gain = RL / (RE + r'e) = 3.6KΩ / (1KΩ + 22.1Ω) = 3.52 This is a far cry from 120.
How did you get 27.45?
eis4497
Joined Jul 6, 2019
16
Gain at low frequencies = RL / (RE + r'e) = 3.6KΩ / (1KΩ + 22.1Ω) = 3.52
Gain at high frequencies = RL / r'e = 3.6KΩ / 22.1Ω = 162.90
What would the threshold be for low vs high frequencies, given an audio range
of 20Hz to 20Khz?
Audioguru
Joined Dec 20, 2007
11,248
The 1k ohms emitter resistor is bypassed with a 10uF capacitor so they result in 16 ohms at 1kHz. Since re is 22.1 ohms then the total emitter load impedance is 38.1 ohms and the gain at 1kHz should be 3600/38.1= 94.5 times.
At 20Hz, the reactance of the 10uF emitter capacitor is 800 ohms so the gain will be 3600/822= 4.38 times.
At 20kHz the stray capacitance of the circuit is low but a shielded audio cable capacitance might reduce the level of the high audio frequency.
eis4497
Joined Jul 6, 2019
16
Thanks.
When I use a directive to modify the 2N3904 transistor specs, Spice says that there is a duplicate definition for the
2N3904. I thought that the directive would override the original definition.
Audioguru
Joined Dec 20, 2007
11,248
A simulation software "guesses" on the exact spec's of a transistor and picks an average or typical one, not one with minimum or maximum spec's.
But you are supposed to know that the reactance of a capacitor at high frequencies is very low, almost a short circuit to the AC.
eis4497
Joined Jul 6, 2019
16
What?
Audioguru
Joined Dec 20, 2007
11,248
Pick a transistor like a 2N3904. Its datasheet shows a range of hFE is from 100 to 300 at a current of 10mA and the hFE might be only 40 at lower or higher current.
You can bias it at the typical hFE of 200 and a simulation (guessing that the typical hFE is 200) will show it working well, but one you buy with a lower or higher hFE will be totally messed up.
You need to design the transistor circuit so it works well when its hFE is low or is high, not just the typical number that a simulation program shows.
The voltage gain at high frequencies is increased when the reactance of the emitter capacitor is in parallel with the emitter resistor.
eis4497
Joined Jul 6, 2019
16
OK Thanks.
