CE amplifier Voltage gain .. Help
HARASI
Joined Apr 22, 2009
12
hobbyist CE capacitor see form his terminal RE resistor and parallel connect resistance seen from emitter looking into the BJT ( R1||R2 / (β+1) + re )
So CE time constant is equal
T = CE * Rt
Rt = RE || ( R1||R2 / (β+1) + re ≈ re
So for 50Hz we get
Ce > 0.16/ ( 50Hz * 26mV/3mA ) = 369uF
OK I have applied the capacitance values which you gave me & simulate the circuit I can see difference but the output signal does not look normal!
Also can you please give the equations you used for calculating C1 & C2. One more thing I forgot is that my instructor gave me this value (Vt=2.6mv) am not sure what is this & did not use it on any of my calculations. :confused:
I have attached the ORCAD .dsn file for my circuit so you can have a look at it in a better way but please note that I renamed the file & added extension ".zip" so forum uploaded can accept it so please rename it & delete the (.zip) so u can open with pspice
Jony130
Joined Feb 17, 2009
5,598
The only given values are:
Voltage Gain= 70
Lower cutoff frequency= 70 Hz
Load Resistance= 7k ohm
Vce= 7v
Ic= 3mA
For this parameters it is better to use this schematic
I assume Ve = 1V and Vce = VRc = 7V, and β = 100.
Vcc = 1V + 2*7V = 15V
Rc = 7V/3mA = 2.2kΩ
Re1 = 1V/3mA = 330Ω
Vb = 3mA * 330Ω + 0.65V = 1.65V
Ib = 3mA/100 = 30
μA (base current)
R2 = Vb / ( 10 * Ib) = 5.1KΩ
R1 = ( Vcc - Vb) / ( 11 * Ib) = 39KΩ
So know if we want voltage gain 70V/V
Au = 70 = (Rc|| RL) / ( re + (Re1||Re2) )
( re + (Re1||Re2) ) = (Rc|| RL) / 70 = 1.6KΩ/70 = 22Ω
22Ω = ( 8.7Ω + (330||Re2) )
Re2 = ( 330 * 13.3 ) / (330 - 13.3) = 13.8 =[ B]15Ω[/B]
Lower cutoff frequency= 70 Hz, becaues we have three High Pass Filters connect in series.
We must design Fc = √ ((70^2) / 3)= 40Hz
C1 = 0.16/ ( 40Hz * R1||R2|| [ β+1 * ( re + (Re1||Re2) ) ) = 0.16/ ( 40 * 1.5K) = 2.6uF = 3.3uF
C2 = 0.16/(40Hz * (Rc+RL) ) = 470nF
Ce = 0.16/ ( 40Hz * Re2) = 333uF=470uF
HARASI
Joined Apr 22, 2009
12
this is a very professional way but sadly I got it late & I saw the need of adding one more resistor Re2 which made the circuit give accurate output.. but I have used some different method which gave me different components values but output was 70 as needed.
Jony130
Joined Feb 17, 2009
5,598
Ok, so without change the schematics
Vce = 7V
Ic = 3mA
RL = 7K
Au = 70 V/V
Au = Rc||RL/re = Rc||7K / ( 26mV/3mA) = Rc||7K/8.7
Ω
Rc||RL = 70 * 8.7
Ω = 609Ω
Rc = (7K * 609) / (7K - 609) = 667.031763Ω = 680Ω
Re = 1V/3mA = 330Ω
Vcc = 1V + 7V + Ic*Rc = 10V
R1 = ( Vcc - Vb) / ( 11 * Ib) = 24KΩ
C1 =0.16/(Fc * R1||R2||(β+1)*re≈ 0.16/ ( 40Hz * 101*8.7Ω) = 4.7uF
C2 = 0.16/(Fc*Rc+RL) = 680nF
Ce = 0.16/( Fc * re) = 470uF
HARASI
Joined Apr 22, 2009
12
This one is great but I have some questions:
(((Au = Rc||RL/re = Rc||7K / ( 26mV/3mA) = Rc||7K/8.7Ω)))
where did you got the 26mv from?
(((C1 =0.16/(Fc * R1||R2||(β+1)*re≈ 0.16/ ( 40Hz * 101*8.7Ω) = 4.7uF)))
I believe fc is the cutoff freq. which was given as 70Hz but you have substituted 40Hz!! Am I right?
Jony130
Joined Feb 17, 2009
5,598
26mV is a thermal voltage
http://en.wikipedia.org/wiki/Boltzmann_constant#Role_in_semiconductor_physics:_the_thermal_voltage
Yes I substituted 40Hz
Becaues in you amplifier you have three high pas filters connect in series.
So the net (equivalent)
cutoff freq. is equal:
Fc = √ (F1^2 + F2^2 + F3^3)
And you wont Fc= 70Hz, and if we assume F1=F2=F3 then
F1 = √(Fc^2)/3 = √(70^2)/3=√(4900/3) ≈ 40Hz
And we cheek the result
Fc = √ (F1^2 + F2^2 + F3^3) = √(40^2+40^2+40^2) =69Hz
Audioguru
Joined Dec 20, 2007
11,248
It is difficult to calculate the voltage gain from the output to input ratio because the output has 20% to 30% distortion. Its positive-going peaks are compressed.
Here is an example of the distortion:
HARASI
Joined Apr 22, 2009
12
I did the simulation & added Vin/Vout as my Trace on pspice. It gave me almost 70 if we ignore distortions. I think it is close enough.
Finally am done with my project & submitted the final report today. Appreciate your help guys.
