CDI Ignition System
Dodgydave
Joined Jun 22, 2012
11,395
It looks like a bleed resistor , to discharge the capacitor when the ignition is turned off, this is a motorcycle ignition.
Janis59
Joined Aug 21, 2017
1,894
L+C makes resonant tank. Serial resonant tank makes Voltage Multiplication with factor of Q what may stand between 50 and 1000. Then, primary voltage may get close to 10 kilovolts what sure will knock out the thyristor. Thus resistor is diminishing systemic Quality Factor to be safe low.
28,269
There are a number of possible reasons for that resistor, including most of those already given.
BUT with the rest of the circuit not shown, an accurate analysis is not possible.
An automotive CD ignition system is fairly complex, and consider that the SCR must switch off quite rapidly to avoid damping the oscillations in the coil and to get ready for the next spark, the resistor may be serving a number of purposes. Without the rest of the circuit we can only guess.
