You are right.If i stick 9V into an input on this chip, will I get 0V out and visa versa?
'Hex' is not fancy. It just means 'six'. As in, six inverters....despite its fancy name "Hex Inverter"...
If your Vdd is 9V, then, yes, you will get approximately 9V from an unloaded output. But that 9V will be at a relatively high impedance (compared to, say, Vdd). If you load the output, it will not be 9V.If i stick 9V into an input on this chip, will I get 0V out and visa versa?
