CD4066 with one control pin equivalent
mos_6502
Joined Dec 11, 2017
84
Why not just tie all 4 together? then it's just one control pin?
Yes, my aim is to launch a chip with a greater number of switches than the 4066, but with a single command pin (those with a serial interface are not good, with a single command I must be able to command all the switches and each switch must be analog and bidirectional)
mos_6502
Joined Dec 11, 2017
84
OT
It is possible, But I preferred use the MOS_6502 account. Sorry if I used two account but I am using two devices (PC and smartphone) and it is possible that I habve registered with different account on this two devices. It is possible tio leave only one account, please? I'm sorry for the inconvenience...
/OT
WBahn
Joined Mar 31, 2012
33,182
MOD NOTE: Definitely recommend using the mos_6502 account since the other account is your e-mail address, which exposes you to spam and AAC to being a more attractive target for bots that collect e-mail addresses. We can then change the name on that account and apply a permanent ban. The content will remain, but you won't be able to log into it.
WBahn
Joined Mar 31, 2012
33,182
MOD NOTE: Sounds good. I've reported the first post, asking an admin to change the name to something innocuous, and will apply a permanent ban. This may take some time to happen, so please just use the mos account from now on.
