cd4046 wave form problem
Amir Sarikhan
Joined May 29, 2015
45
Hi all
I used a cd4046 to to produce a square and triangle wave
It has a constant current on the capacitor pin so producing also a triangular wave form on that pin . The circuit works well at pspice
but in my board I get different results as pictures below
please help me
38,548
You don't show a schematic of the constant-current source and my crystal ball is out-of-order, so how can we tell what's wrong?
Amir Sarikhan
Joined May 29, 2015
45
Hi thanks for your response . I read on a web site that it has some kind of constant current on capacitor pins and it is shown on spice simulation but the problem is that on board I did not get same result .what is the reason ?
Kjeldgaard
Joined Apr 7, 2016
476
Now I have to refresh how the VCO in the 4046 is constructed. A example of the data sheet can be Texas Instruments: CD4046
On page 11, there is an expanded block diagram of the VCO. It can be seen that the timing capacitors one end is connected to ground when charging with the constant current of opposite end of the capacitor, and after a half cycle time is changed to the opposite terminals of the capacitor.
So that will measure a sawtooth curve when measured at one end of the time capacitor.
http://www.ti.com/lit/an/scha002a/scha002a.pdf
Amir Sarikhan
Joined May 29, 2015
45
Why do you have pin 15 connected to V+?
It should be left open or connected to ground.
it is connected to ground not v+
thanks
I read that page
you say right
but why pspice draws a triangular wave ?
38,548
Yes, I mis-traced the connection.
Kjeldgaard is correct. You will measure a sawtooth voltage from one end of the capacitor to common as the circuit shows.
What, exactly is the Pspice plot measuring?
Amir Sarikhan
Joined May 29, 2015
45
